Ir para o conteúdo principal
Asus F554LA-WS52 Keyboard Replacement
O que você precisa
  1. Asus F554LA-WS52 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Asus F554LA-WS52 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Keyboard Replacement: passo 2, imagem 1 %32 Asus F554LA-WS52 Keyboard Replacement: passo 2, imagem 2 %32 Asus F554LA-WS52 Keyboard Replacement: passo 2, imagem 3 %32
    • Flip the notebook back over.
    • Gently lift and remove the keyboard with a plastic opening tool.
  3. Asus F554LA-WS52 Keyboard Replacement: passo 3, imagem 1 %32
    • (Not pictured) Remove the three cables attached to the keyboard and one from the touch-pad.
    • (Not pictured) With the plastic opening tool, pry off the metal separation plate from the keyboard.
    • (Not pictured) With the plastic opening tool, gently pry the keyboard from its position and replace.
Conclusão
Aaron Ratliff
Membro desde: 10/09/18
527 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G2, Leahy Fall 2018 Membro de USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 332
