Ir para o conteúdo principal
Asus F554LA-WS52 Disc Drive
O que você precisa
  1. Asus F554LA-WS52 Disc Drive, Disc Drive: passo 1, imagem 1 %32 Asus F554LA-WS52 Disc Drive, Disc Drive: passo 1, imagem 2 %32
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Disc Drive: passo 2, imagem 1 %32 Asus F554LA-WS52 Disc Drive: passo 2, imagem 2 %32 Asus F554LA-WS52 Disc Drive: passo 2, imagem 3 %32
    • With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
    • (Not pictured) Remove the three cables attached to the keyboard and one touch-pad.
  3. Asus F554LA-WS52 Disc Drive: passo 3, imagem 1 %32 Asus F554LA-WS52 Disc Drive: passo 3, imagem 2 %32
    • Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
    • Remove the small rectangular hard drive-motherboard connection board.
    • (Not pictured) Remove the hard drive.
  4. Asus F554LA-WS52 Disc Drive: passo 4, imagem 1 %32 Asus F554LA-WS52 Disc Drive: passo 4, imagem 2 %32
    • Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
    • Remove the battery.
  5. Asus F554LA-WS52 Disc Drive: passo 5, imagem 1 %32 Asus F554LA-WS52 Disc Drive: passo 5, imagem 2 %32 Asus F554LA-WS52 Disc Drive: passo 5, imagem 3 %32
    • Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
    • With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
Conclusão
Aaron Ratliff
Membro desde: 10/09/18
527 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G2, Leahy Fall 2018 Membro de USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 581
