Ir para o conteúdo principal
Asus EeeBook X205TA TrackPad Replacement
O que você precisa
  1. Asus EeeBook X205TA TrackPad Replacement, TrackPad: passo 1, imagem 1 %32 Asus EeeBook X205TA TrackPad Replacement, TrackPad: passo 1, imagem 2 %32
    • Remove ten Phillips #00 screws located on the bottom of the laptop:
    • Seven short screws.
    • Three long screws.
  2. Asus EeeBook X205TA TrackPad Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case (where the hinge is).
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA TrackPad Replacement: passo 3, imagem 1 %32 Asus EeeBook X205TA TrackPad Replacement: passo 3, imagem 2 %32
    • Using the 2mm Phillips Screwdriver, carefully unscrew the four screws holding the track pad.
    • Using the Phillips #00 Screwdriver, unscrew the three screws holding the track pad.
  4. Asus EeeBook X205TA TrackPad Replacement: passo 4, imagem 1 %32
    • Unplug the ZIF connector
  5. Asus EeeBook X205TA TrackPad Replacement: passo 5, imagem 1 %32
    • Carefully pull the track pad from the side
Conclusão
Lorena Santiago
Membro desde: 10/06/16
712 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-2, Sullivan Fall 2016 Membro de USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 1,739
