Introdução
In this guide you will learn how to replace the speakers in an Asus EeeBook X205TA.
O que você precisa
Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Locate and lift the tabs from the LED/motherboard ribbon cable.
Remove the cable.
Uma outra pessoa concluiu este guia.
2 comentários
Thanks. You’ve helped make it clearer for me!
