Ir para o conteúdo principal
Asus EeeBook X205TA Speakers Replacement
O que você precisa
  1. Asus EeeBook X205TA Speakers Replacement, Battery: passo 1, imagem 1 %32 Asus EeeBook X205TA Speakers Replacement, Battery: passo 1, imagem 2 %32
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Speakers Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Speakers Replacement: passo 3, imagem 1 %32 Asus EeeBook X205TA Speakers Replacement: passo 3, imagem 2 %32
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Speakers Replacement: passo 4, imagem 1 %32
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Speakers Replacement: passo 5, imagem 1 %32
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA Speakers Replacement, Speakers: passo 6, imagem 1 %32
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA Speakers Replacement: passo 7, imagem 1 %32
    • Unplug the speaker cable from the motherboard.
  8. Asus EeeBook X205TA Speakers Replacement: passo 8, imagem 1 %32
    • Pry the right speaker gently with the plastic opening tool.
  9. Asus EeeBook X205TA Speakers Replacement: passo 9, imagem 1 %32
    • Pry the left speaker gently with the plastic opening tool.
Conclusão
Uma outra pessoa concluiu este guia.
William Riggins
Membro desde: 03/21/17
312 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G4, Baechle Spring 2017 Membro de IUPUI, Team S3-G4, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G4
Membros da 4
Autoria de 6 guias
2 comentários
Thank you very much for this detailed and helpful tutorial.
andrew - Responder
Thanks. You’ve helped make it clearer for me!
geometry dash
Martin Tolley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 893
