Ir para o conteúdo principal
Asus EeeBook X205TA Screen Assembly Replacement
O que você precisa
  1. Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: passo 1, imagem 1 %32 Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: passo 1, imagem 2 %32
    • Unscrew all 10 screws located on the bottom of the laptop using 2mm Phillips Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA Screen Assembly Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Screen Assembly Replacement: passo 3, imagem 1 %32 Asus EeeBook X205TA Screen Assembly Replacement: passo 3, imagem 2 %32 Asus EeeBook X205TA Screen Assembly Replacement: passo 3, imagem 3 %32
    • Unscrew the four screws using Philips #2 screwdriver that connect the screen to the inside of the case for the laptop.
  4. Asus EeeBook X205TA Screen Assembly Replacement: passo 4, imagem 1 %32
    • Unplug the No-Fuss Ribbon connector of the screen from the motherboard.
    • Carefully lift the screen away from the case.
Conclusão
3 outras pessoas executaram este guia.
Lorena Santiago
Membro desde: 10/06/16
712 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-2, Sullivan Fall 2016 Membro de USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
Membros da 3
Autoria de 10 guias
Um comentário
What's that small black screen hanging out from the laptop
Tayler Grant - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 2,372
