Ir para o conteúdo principal
Asus EeeBook X205TA Motherboard Replacement
O que você precisa
  1. Asus EeeBook X205TA Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Asus EeeBook X205TA Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Unscrew all 10 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Motherboard Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Motherboard Replacement: passo 3, imagem 1 %32 Asus EeeBook X205TA Motherboard Replacement: passo 3, imagem 2 %32
    • Unscrew all seven screws around the outer edge of the motherboard using 2mm Phillips Screwdriver.
  4. Asus EeeBook X205TA Motherboard Replacement: passo 4, imagem 1 %32 Asus EeeBook X205TA Motherboard Replacement: passo 4, imagem 2 %32
    • Unplug the No-Fuss Ribbon battery, screen, and speakers from the motherboard.
    • Carefully remove the ZIF screen connector.
Conclusão
10 outras pessoas executaram este guia.
Shahir Makary
Membro desde: 10/06/16
294 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-2, Sullivan Fall 2016 Membro de USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
Membros da 3
Autoria de 10 guias
3 comentários
Very clear and precise instructions. Thanks
wdkandler - Responder
Here is a more detailed view of all the cables that have to be unplugged before the motherboard can be extracted: https://ibb.co/jcgwUQ
Also, be aware that, even after all screws and cables are removed, it will still require a little bit of force to remove the motherboard, due to the thermal adhesive on the CPU and GPU. Do not be afraid to pull the motherboard! As long as you followed the instructions and disconnected all the EIGHT cables and SEVEN screws, you are not going to damage anything, it’s just thermal tape!
Sebastian Swirski - Responder
I guess because if the spill damage, the motherboard stop my keyboard from working and the usual from
Tayler Grant - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 38
Duração total: 6,783
