Ir para o conteúdo principal
Asus EeeBook X205TA LED Screen Panel Chip Replacement
O que você precisa
  1. Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: passo 1, imagem 1 %32 Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: passo 1, imagem 2 %32
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA LED Screen Panel Chip Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA LED Screen Panel Chip Replacement: passo 3, imagem 1 %32 Asus EeeBook X205TA LED Screen Panel Chip Replacement: passo 3, imagem 2 %32
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA LED Screen Panel Chip Replacement: passo 4, imagem 1 %32
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA LED Screen Panel Chip Replacement: passo 5, imagem 1 %32
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA LED Screen Panel Chip Replacement, LED Screen Panel Chip: passo 6, imagem 1 %32
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA LED Screen Panel Chip Replacement: passo 7, imagem 1 %32
    • Unscrew the 1 JIS 2mm screw with the J0 bit.
  8. Asus EeeBook X205TA LED Screen Panel Chip Replacement: passo 8, imagem 1 %32
    • Remove the chip.
Conclusão
Rachael
Membro desde: 03/20/17
125 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G4, Baechle Spring 2017 Membro de IUPUI, Team S3-G4, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 1,218
