Introdução
This guide will help you replace your Asus EeeBook X205TA keyboard key-cap if it is damaged or the letter has worn off your key. This guide can be used for any key-cap on the keyboard.
O que você precisa
Gently pry the bottom edge of key with a plastic opening tool until it flips up.
4 outras pessoas executaram este guia.
