Introdução
This guide will help you replace your Asus EeeBook X205TA in case your battery is dead, dying, or won't hold a charge. If disposing battery, please follow the laws and regulations for proper disposal.
O que você precisa
Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Follow the guide in reverse order to reassemble the device.
8 outras pessoas executaram este guia.
11 comentários
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
No, you must have the battery on.
If you have one….
My battery is stuck on orange led mode. My laptop cannot identify the battery….
