Ir para o conteúdo principal
Asus EeeBook X205TA Battery Replacement
O que você precisa
  1. Asus EeeBook X205TA Battery Replacement, Battery: passo 1, imagem 1 %32 Asus EeeBook X205TA Battery Replacement, Battery: passo 1, imagem 2 %32
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: passo 3, imagem 1 %32 Asus EeeBook X205TA Battery Replacement: passo 3, imagem 2 %32
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: passo 4, imagem 1 %32
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: passo 5, imagem 1 %32
    • Carefully lift the battery out of the laptop.
Conclusão
Follow the guide in reverse order to reassemble the device.
8 outras pessoas executaram este guia.
Lorena Santiago
Membro desde: 10/06/16
712 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-2, Sullivan Fall 2016 Membro de USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
Membros da 3
Autoria de 10 guias
11 comentários
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - Responder
No, you must have the battery on.
Tayler Grant -
is this under warenty
bla bla - Responder
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 71
Duração total: 13,890
