Ir para o conteúdo principal
Asus EeeBook X205TA USB Port Replacement
O que você precisa
  1. Asus EeeBook X205TA  USB Port Replacement, USB Port: passo 1, imagem 1 %32 Asus EeeBook X205TA  USB Port Replacement, USB Port: passo 1, imagem 2 %32
    • Unscrew all 10 screws located on the bottom of the laptop using a Phillips #2 Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA  USB Port Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA  USB Port Replacement: passo 3, imagem 1 %32 Asus EeeBook X205TA  USB Port Replacement: passo 3, imagem 2 %32
    • The USB ports are located on the strip that looks like the motherboard on the left side of the laptop next to the battery.
    • Unscrew the four screws using Philips #2 screwdriver located around the edge of the USB ports.
    • Unplug the battery ZIF connector from the USB ports.
  4. Asus EeeBook X205TA  USB Port Replacement: passo 4, imagem 1 %32
    • Carefully remove the USB ports from the laptop.
Conclusão
3 outras pessoas executaram este guia.
Lorena Santiago
Membro desde: 10/06/16
736 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-2, Sullivan Fall 2016 Membro de USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 2,781
