Introdução
The Asus Eee PC 900 uses a small solid state drive instead of a lrger hard drive. Use this guide to replace the SSD in the Asus Eee PC 900.
O que você precisa
Slide the battery's locking tabs from the locked position to unlocked positions.
Slide the battery out while holding the left locking tab in the unlocked position.
a (minor good, as liion batteries tend to degrade, esp in alltimeuse in bay: warm, max voltage=minimumlifespan) solution is:
try to revive the no more recognized one! first!!
either at the poles: need three connections: two at the ends, one in the middle like 1(+ -)-2-(+-)3
(need a hole through the casing/housing… (each of the two packs must be over 3.0volts: you can easily put a good charged liion from outside for a few moments to get a bit charge in to rise each pack over the 3.0 threshold that prevents pack of being recocknized as ok…)
or need a bridge at the connector to see realbatterypackvoltage there… check it out
good luck, thomas@biopilze.de
addendum:
if too old, too long lying at voltages under 3v… well possible that the liions wont keep the voltage, then at least one of two packs: (each two parallel 18650 liions) are gone -in that case you could try to dissassemble casing and replace a /or both pack/s, but is rather difficult: housing is a: well glued, try to open with sharpe knive but take extreme care not to destroy or short sircuit internals!!!!!! and b: is brittle and not much space for adding solder etc… -alltogether a thorny way…
you could just add external batteries at these poles, too… -if the originalones have just a high impedence/resistance, but do NOT leak (low impedence/resistance), otherwise constant energy-loss + heating… : problem: eeepc checks voltage-drift and regulates power-up/booster… if you added to much more voltage , as a flyby addendum: it rekocknizeses overload and shuts down imediately: so try to add batteries with similar voltage, possibly via a smal resisor first that buffers drain… give feedback to me please!
>>…or need a bridge at the connector to see realbatterypackvoltage there… check it out
the connector has generally spoken: plus, minus, switch, thermal-control… some: ie2, too…
did that for a eeeepc900, external charge just at the connector, worked fine, now got eeepc900a, is different: one pin less, have to find out myself first… today did no more find any schematics in the web yet -any suggestions folks?
Remove the small sticker on the right side of the SSD/RAM compartment cover.
Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
7 outras pessoas executaram este guia.
5 comentários
Refering from this site: http://www.minipciessd.com/
It seems you'll need a miniPCIe SSD and not a m-sata (even if the form factor seems the same) and that's why your bios doesn't recognize it.
Same problem here. I ended up putting my “new!” 64GB SSD in an adaptor and used it for a few years until it wore out!
Evidently the chips aren’t much good as withstood less than 700GB of writes according to the onboard diagnostics.
Strangely enough the adaptor worked with the original 16GB SSD and the 64.
what kind of adapter you use? My ssd died….
