Introdução
RAM acts as temporary storage on your device that will occasionally fault or run out of memory. If you need to replace or install new RAM on your Asus Eee PC 900, follow the directions below. Before beginning, make sure the device is powered off and is not connected to any power source.
O que você precisa
Slide the battery's locking tabs from the locked position to unlocked positions.
5 outras pessoas executaram este guia.
