Ir para o conteúdo principal
Asus Eee PC 1215N Top Cover (Touchpad) Replacement
O que você precisa
  1. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Battery: passo 1, imagem 1 %32 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Battery: passo 1, imagem 2 %32
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: passo 2, imagem 1 %32 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: passo 2, imagem 2 %32 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: passo 2, imagem 3 %32
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: passo 3, imagem 1 %32
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: passo 4, imagem 1 %32 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Spudger
    $3.99
    Comprar
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  5. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Top Cover (Touchpad): passo 5, imagem 1 %32
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: passo 6, imagem 1 %32 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: passo 6, imagem 2 %32 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: passo 6, imagem 3 %32
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
  7. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: passo 7, imagem 1 %32 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: passo 7, imagem 2 %32
    Spudger
    $3.99
    Comprar
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
Conclusão
Gaetan
Membro desde: 12/26/12
9.574 Reputação
Autoria de 18 guias
Um comentário
Unrelated. My Asus VX-6 recently had the blue USB 3.0 ports stop working. Now the Ethernet connection is intermittent, goes away, come back, over and over again. Are those 3 ports on the right hand side part of the main board or separate boards?
paul poco - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 2,713
