O que você precisa
Turn the power off and turn the netbook upside down.
Slide both battery catches together to release the battery.
Slide the battery out.
Remove screws on the battery compartment.
Locate the memory compartment.
Using a Plastic Opening Tools, remove the screw rubber cover.
Remove the screw.
Remove the screws as necessary.
For top cover removing, only remove the 2 bottom screws.
The one short screw paterns to uper left screw hole directly on the PCB.
Remove the keyboard 4 screws on the bottom.
Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
Uma outra pessoa concluiu este guia.
