Introdução
ASUS Eee PC 1215N is equipped with a easy removable battery. First Step before any disassembly is to remove the battery.
Turn the power off and turn the netbook upside down.
Slide both battery catches together to release the battery.
Slide the battery out.
Uma outra pessoa concluiu este guia.
While there is a fairly long list of tools listed here, I was able to complete the entire guide using only a 3/64" flathead mini screwdriver (the kind you get for $0.99). I replaced the stock 500GB 5400RPM drive with the updated 7200RPM slim drive of the same line with no issues. The BIOS picked it up immediately, and I need only reinstall an OS.
Tolidano - Responder
Missing step: remove the two screws under the battery, otherwise the keyboard won’t come off
Andrea Borgia - Responder
