Introdução
In the event that your Asus Eee PC 1201N's hard drive is faulty this guide will show you exactly how to do that. It will only require a screwdriver and a plastic opening tool.
O que você precisa
Open the netbook to find the four small grooves along the top of the keyboard.
Pry the keyboard up using the plastic opening tool.
Turn the netbook over and remove the eight 6.5mm screws using the J0 Phillips head screwdriver.
4 outras pessoas executaram este guia.
