Ir para o conteúdo principal
Asus Eee PC 1201N Battery Replacement
  1. Asus Eee PC 1201N Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Battery Replacement: passo 2, imagem 1 %32
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Battery Replacement: passo 3, imagem 1 %32
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 2-3, Nance Fall 2016 Membro de USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 1,013
