Ir para o conteúdo principal
Asus Eee PC 1201HAB Hard Drive Replacement
O que você precisa
  1. Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: passo 1, imagem 1 %32 Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: passo 1, imagem 2 %32
    • Use a plastic opening tool and carefully pry the top panel from the base.
  2. Asus Eee PC 1201HAB Hard Drive Replacement: passo 2, imagem 1 %32 Asus Eee PC 1201HAB Hard Drive Replacement: passo 2, imagem 2 %32 Asus Eee PC 1201HAB Hard Drive Replacement: passo 2, imagem 3 %32
    • Slowly lift the keyboard from the base.
    • Disconnect the attached ribbon from under the keyboard.
  3. Asus Eee PC 1201HAB Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove the keyboard.
  4. Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Lay the laptop with the back facing up.
    • With a Phillips #0 screwdriver, remove the eight 6mm screws on the back of the laptop.
  5. Asus Eee PC 1201HAB Hard Drive Replacement: passo 5, imagem 1 %32 Asus Eee PC 1201HAB Hard Drive Replacement: passo 5, imagem 2 %32 Asus Eee PC 1201HAB Hard Drive Replacement: passo 5, imagem 3 %32
    • Slide the tabs outward to remove the battery.
  6. Asus Eee PC 1201HAB Hard Drive Replacement: passo 6, imagem 1 %32 Asus Eee PC 1201HAB Hard Drive Replacement: passo 6, imagem 2 %32
    • Flip the device so that you are facing the screen.
    • Remove the ten 4mm screws on the silver panel under the keyboard using a Phillips #0 screwdriver.
  7. Asus Eee PC 1201HAB Hard Drive Replacement: passo 7, imagem 1 %32 Asus Eee PC 1201HAB Hard Drive Replacement: passo 7, imagem 2 %32 Asus Eee PC 1201HAB Hard Drive Replacement: passo 7, imagem 3 %32
    • Using a plastic opening tool, remove the top panel of the laptop.
  8. Asus Eee PC 1201HAB Hard Drive Replacement: passo 8, imagem 1 %32 Asus Eee PC 1201HAB Hard Drive Replacement: passo 8, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the four 4mm screws connecting the hard drive.
  9. Asus Eee PC 1201HAB Hard Drive Replacement: passo 9, imagem 1 %32
    • Remove and replace the hard drive.
Conclusão
Uma outra pessoa concluiu este guia.
Katherine Chan
Membro desde: 10/22/18
353 Reputação
Autoria de 2 guias
Equipe
UC Davis, Team S7-G3, Lore Fall 2018 Membro de UC Davis, Team S7-G3, Lore Fall 2018
UCD-LORE-F18S7G3
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 770
