Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
This guide will provide aid in replacing mouse clickers for users experiencing problems with the mouse clicker such as sensitivity. The user will remove the keyboard and simply unscrew the part.
  1. Use flathead screwdriver or a similar tool to carefully remove top panel of base
    • Use flathead screwdriver or a similar tool to carefully remove top panel of base
  2. Pull up on small white locks on ribbons (circled in red) to release ribbons Unscrew the two 4mm screws on either side of the circuitboard to remove broken component
    • Pull up on small white locks on ribbons (circled in red) to release ribbons
    • Unscrew the two 4mm screws on either side of the circuitboard to remove broken component
Conclusão
Uma outra pessoa concluiu este guia.
Michael Dooley
Membro desde: 18-04-2013
132 Reputation
3 Guias de autoria
Equipe
Cal Poly, Team 21-52, Johann Spring 2013 Membro de Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Membros
11 Guias de autoria
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 699
