Ir para o conteúdo principal
Asus Eee PC 1008ha Graphics Card Replacement
O que você precisa
  1. Asus Eee PC 1008ha Graphics Card Replacement, Battery: passo 1, imagem 1 %32
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Graphics Card Replacement: passo 2, imagem 1 %32 Asus Eee PC 1008ha Graphics Card Replacement: passo 2, imagem 2 %32 Asus Eee PC 1008ha Graphics Card Replacement: passo 2, imagem 3 %32
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Graphics Card Replacement: passo 3, imagem 1 %32 Asus Eee PC 1008ha Graphics Card Replacement: passo 3, imagem 2 %32
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Graphics Card Replacement, Graphics Card: passo 4, imagem 1 %32
    • Remove the two 2mm screws from the graphics card.
  5. Asus Eee PC 1008ha Graphics Card Replacement: passo 5, imagem 1 %32 Asus Eee PC 1008ha Graphics Card Replacement: passo 5, imagem 2 %32 Asus Eee PC 1008ha Graphics Card Replacement: passo 5, imagem 3 %32
    • Flip over the graphics card.
    • Pull the black plastic locking mechanism towards the golden ribbon to unlock.
    • Pull out the ribbon.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Powers
Membro desde: 04/17/13
101 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 21-52, Johann Spring 2013 Membro de Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
Membros da 4
Autoria de 11 guias
Um comentário
Is this the graphics card?
Is this pc has no integrated graphics card?
JUAN LUIS GARCIA BRAVO - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 3,608
