Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
You will be the remove of the battery and continue to cautiously take the graphics card off of the laptop. This installation would be necessary if a user has a fried, defected, or inoperative in general.
  1. Using the plastic opening tool, carefully pry the top panel from the base.
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Lift the side of the keyboard. Disconnect the attached ribbon located underneath the keyboard. Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Use your fingers to lift the battery and gently disconnect the wires from the base. Use your fingers to lift the battery and gently disconnect the wires from the base.
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Remove the two 2mm screws from the graphics card.
    • Remove the two 2mm screws from the graphics card.
  5. Flip over the graphics card. Pull the black plastic locking mechanism towards the golden ribbon to unlock. Pull out the ribbon.
    • Flip over the graphics card.
    • Pull the black plastic locking mechanism towards the golden ribbon to unlock.
    • Pull out the ribbon.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Powers
Membro desde: 17-04-2013
101 Reputation
2 Guias de autoria
Equipe
Cal Poly, Team 21-52, Johann Spring 2013 Membro de Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Membros
11 Guias de autoria
Is this the graphics card?
Is this pc has no integrated graphics card?
JUAN LUIS GARCIA BRAVO - Responder
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 3,047
