Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This task will normally be performed if the fan is faulty, broken, or if the user is trying to disassemble the entire device. You will start with removing the keyboard and continue to carefully remove parts within the laptop to finally disconnect fan for replacement.
  1. Using the plastic opening tool, carefully pry the top panel from the base.
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Lift the side of the keyboard. Disconnect the attached ribbon located underneath the keyboard. Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use your fingers to lift the battery and gently disconnect the wires from the base. Use your fingers to lift the battery and gently disconnect the wires from the base.
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  5. Remove the 2mm screws on the copper heat sink on the left side of the device. Use a flathead screwdriver to remove the heat sink. Make sure to remove the adhesive tape from the top of the heat sink. Use a flathead screwdriver to remove the heat sink. Make sure to remove the adhesive tape from the top of the heat sink.
    • Remove the 2mm screws on the copper heat sink on the left side of the device.
    • Use a flathead screwdriver to remove the heat sink. Make sure to remove the adhesive tape from the top of the heat sink.
  6. Remove the small white connector attached to the fan (make sure to pull from the white connector and not with the wires as this can cause damage to the component) Replace with new fan!
    • Remove the small white connector attached to the fan (make sure to pull from the white connector and not with the wires as this can cause damage to the component)
    • Replace with new fan!
Conclusão
2 outras pessoas concluíram este guia.
Michael Dooley
Membro desde: 18-04-2013
132 Reputação
3 Guias de autoria
equipe
Cal Poly, Team 21-52, Johann Spring 2013 Membro de Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Membros
11 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,482
