Introdução
The RAM is located under the plastic casing of the laptop. Before starting the guide, make sure the laptop's charger is not plugged in.
O que você precisa
Start by having the laptop upside down on a hard flat surface.
Find and unscrew the 6.65 mm Phillips #1 screw.
Uma outra pessoa concluiu este guia.
Um comentário
Everything I've read says you can only upgrade from the 1gb ram to a 2gig. Here's what I just installed: http://amzn.to/2x0flty and so far its working great...I notice a difference in speed, although this thing is still slow.
