Ir para o conteúdo principal
Asus Eee PC 1005HA Screen Replacement
O que você precisa
  1. Asus Eee PC 1005HA Screen Replacement, Battery: passo 1, imagem 1 %32
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Screen Replacement: passo 2, imagem 1 %32 Asus Eee PC 1005HA Screen Replacement: passo 2, imagem 2 %32 Asus Eee PC 1005HA Screen Replacement: passo 2, imagem 3 %32
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Screen Replacement, Screen: passo 3, imagem 1 %32 Asus Eee PC 1005HA Screen Replacement, Screen: passo 3, imagem 2 %32 Asus Eee PC 1005HA Screen Replacement, Screen: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, remove the six screw covers on the screen bezel.
    • Remove the six 4.6 mm screws from the bezel.
  4. Asus Eee PC 1005HA Screen Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to disengage the plastic clips that secure the screen bezel to the display.
    • Carefully remove the bezel from the display.
  5. Asus Eee PC 1005HA Screen Replacement: passo 5, imagem 1 %32 Asus Eee PC 1005HA Screen Replacement: passo 5, imagem 2 %32 Asus Eee PC 1005HA Screen Replacement: passo 5, imagem 3 %32
    • Remove the four 3.6 mm screws securing the screen.
    • Slowly lift the screen up from the rest of the laptop.
    • The screen is still attached to the laptop by a set of cables. Be careful not to damage them while removing the screen.
  6. Asus Eee PC 1005HA Screen Replacement: passo 6, imagem 1 %32 Asus Eee PC 1005HA Screen Replacement: passo 6, imagem 2 %32
    • Remove the plastic tape securing the display cables to the back of the screen.
    • Slide the display cable connector out its socket on the back of the screen.
  7. Asus Eee PC 1005HA Screen Replacement: passo 7, imagem 1 %32 Asus Eee PC 1005HA Screen Replacement: passo 7, imagem 2 %32
    • Remove the four 3.1 mm housing screws on the sides of the display housing frame
    • Remove the housing frame.
Conclusão
13 outras pessoas executaram este guia.
Mitchell Cesare
Membro desde: 01/31/12
793 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 11-22, Maness Winter 2012 Membro de Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Duração total: 21,330
