Ferramentas
Peças
Nenhum componente especificado.
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the laptop over.
Using a Phillips #1 screwdriver, remove the five 5.65 mm screws.
Remove the lid to the RAM compartment, if possible.
To remove the RAM, depress the tabs that are holding it in. These tabs are bound in red in the picture.
Use a Phillips #1 screwdriver to remove one 6.5 mm screw located next to the RAM.
Flip the laptop back over, and open the display.
Use a Phillips #1 screwdriver to remove the six 5.5 mm screws on the inside covering.
Detach the five plastic clips holding the upper and lower halves of the laptop together. These can be undone by carefully running a plastic opening tool between the top and bottom casing. There will be an audible audible "click" as the clips come undone.
Once the five clips have been undone, carefully remove the upper half of the laptop.
Detach the track pad ribbon by using a plastic opening tool to raise up the black pad.
Detach the Bluetooth wire located below the fan by gently pulling it upward.
Detach the ribbon cable that connects the SD card module and the motherboard by lifting the black clips using the plastic opening tool.
Remove the two screws holding the SD card panel in place.
Gently lift up the SD card reader from its housing.
