Ir para o conteúdo principal
Asus Eee PC 1005HA Keyboard Replacement
O que você precisa
  1. Asus Eee PC 1005HA Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Keyboard Replacement: passo 2, imagem 1 %32 Asus Eee PC 1005HA Keyboard Replacement: passo 2, imagem 2 %32 Asus Eee PC 1005HA Keyboard Replacement: passo 2, imagem 3 %32
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Asus Eee PC 1005HA Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Keyboard Replacement: passo 4, imagem 1 %32 Asus Eee PC 1005HA Keyboard Replacement: passo 4, imagem 2 %32 Asus Eee PC 1005HA Keyboard Replacement: passo 4, imagem 3 %32
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  5. Asus Eee PC 1005HA Keyboard Replacement: passo 5, imagem 1 %32
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
Conclusão
12 outras pessoas executaram este guia.
Chris Beichler
Membro desde: 01/20/12
582 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-22, Maness Winter 2012 Membro de Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
Membros da 3
Autoria de 12 guias
Um comentário
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
anytimerabin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 23,474
