Introdução
If you are having problems with the RAM on your device, this guide will help you replace it.
O que você precisa
Lay the laptop down with the bottom facing upwards.
Locate the two battery lock slide tabs.
Use a PH00 (+) phillips head to unscrew the two 7 mm screws holding down the back panel.
Use the spudger to pry off the back cover.
