Ir para o conteúdo principal
Asus EEE PC 1000HD Keyboard Replacement
O que você precisa
  1. Asus EEE PC 1000HD Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Note: Prior to changing the keyboard on your laptop, be sure to have a replacement keyboard on hand.
  2. Asus EEE PC 1000HD Keyboard Replacement: passo 2, imagem 1 %32 Asus EEE PC 1000HD Keyboard Replacement: passo 2, imagem 2 %32
    • Use a metal spudger and carefully insert the end of the flat tip into the edge of the keyboard.
    • Hold one end of the keyboard down to make prying easier.
    • Gently lift the metal spudger until you begin hearing clicking noises; these are the sounds of the keyboard unclasping from the board below.
  3. Asus EEE PC 1000HD Keyboard Replacement: passo 3, imagem 1 %32
    • Once you lift the keyboard, there will be a metal tab that connects the keyboard to the metal panel below.
    • Detach this metal tab slowly.
  4. Asus EEE PC 1000HD Keyboard Replacement: passo 4, imagem 1 %32
    • The keyboard should be fully detached.
    • With your new replacement keyboard, insert the metal tab back into the metal panel. Press gently on the keyboard to lock it into place.
    • There should be a few clicking noises as the new keyboard latches onto the metal board.
Conclusão
Emily Gao
Membro desde: 10/17/17
101 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 537
