Ir para o conteúdo principal
Asus Chromebook Flip C302CA Display Replacement
O que você precisa
  1. Asus Chromebook Flip C302CA Display Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Display Replacement: passo 2, imagem 1 %32 Asus Chromebook Flip C302CA Display Replacement: passo 2, imagem 2 %32 Asus Chromebook Flip C302CA Display Replacement: passo 2, imagem 3 %32
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Display Replacement: passo 3, imagem 1 %32 Asus Chromebook Flip C302CA Display Replacement: passo 3, imagem 2 %32 Asus Chromebook Flip C302CA Display Replacement: passo 3, imagem 3 %32
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Display Replacement: passo 4, imagem 1 %32 Asus Chromebook Flip C302CA Display Replacement: passo 4, imagem 2 %32
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Display Replacement, Display: passo 5, imagem 1 %32
    • Remove the black display ports from the motherboard.
  6. Asus Chromebook Flip C302CA Display Replacement: passo 6, imagem 1 %32
    • Remove the six 2.54 mm Phillips screws from the left and right screen hinge brackets.
  7. Asus Chromebook Flip C302CA Display Replacement: passo 7, imagem 1 %32
    • Remove the display unit.
  8. Asus Chromebook Flip C302CA Display Replacement: passo 8, imagem 1 %32
    • Use heat gun to loosen up adhesive on rubber covers for screw.
  9. Asus Chromebook Flip C302CA Display Replacement: passo 9, imagem 1 %32
    • Remove rubber covers.
  10. Asus Chromebook Flip C302CA Display Replacement: passo 10, imagem 1 %32
    • Remove the two 2.5 mm screws.
  11. Asus Chromebook Flip C302CA Display Replacement: passo 11, imagem 1 %32
    • Use prying tool to separate panel from monitor.
  12. Asus Chromebook Flip C302CA Display Replacement: passo 12, imagem 1 %32
    • Remove this connection by pulling to separate it from the monitor.
  13. Asus Chromebook Flip C302CA Display Replacement: passo 13, imagem 1 %32
    • Remove connection point and the entire camera assembly including wires.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 261
