Ir para o conteúdo principal
Asus Chromebook Flip C100P Speaker Replacement
O que você precisa
  1. Asus Chromebook Flip C100P Speaker Replacement, Speaker System: passo 1, imagem 1 %32
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Speaker Replacement: passo 2, imagem 1 %32
    • Remove the five screws from beneath the rubber feet using a philips head screwdriver.
    • The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Speaker Replacement: passo 3, imagem 1 %32
    • Remove the nine bottom cover screws using a T5 screwdriver.
    • Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them.
  4. Asus Chromebook Flip C100P Speaker Replacement: passo 4, imagem 1 %32 Asus Chromebook Flip C100P Speaker Replacement: passo 4, imagem 2 %32 Asus Chromebook Flip C100P Speaker Replacement: passo 4, imagem 3 %32
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require extra power. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Speaker Replacement: passo 5, imagem 1 %32 Asus Chromebook Flip C100P Speaker Replacement: passo 5, imagem 2 %32 Asus Chromebook Flip C100P Speaker Replacement: passo 5, imagem 3 %32
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Speaker Replacement: passo 6, imagem 1 %32 Asus Chromebook Flip C100P Speaker Replacement: passo 6, imagem 2 %32 Asus Chromebook Flip C100P Speaker Replacement: passo 6, imagem 3 %32
    • Disconnect the DC jack cable and the battery cable from the motherboard using tweezers, the pointed end of a plastic spudger, or by simply pulling the cables apart from the motherboard with your fingers.
  7. Asus Chromebook Flip C100P Speaker Replacement: passo 7, imagem 1 %32 Asus Chromebook Flip C100P Speaker Replacement: passo 7, imagem 2 %32
    • Disconnect the speaker cable from the motherboard using tweezers or the pointed end of a plastic spudger.
  8. Asus Chromebook Flip C100P Speaker Replacement: passo 8, imagem 1 %32 Asus Chromebook Flip C100P Speaker Replacement: passo 8, imagem 2 %32 Asus Chromebook Flip C100P Speaker Replacement: passo 8, imagem 3 %32
    • Remove the four 4.2mm speaker screws, then remove the two speakers using a Phillips #0 screwdriver.
Conclusão
To reassemble your device, replace the broken or faulty speaker system with a new speaker system and follow these instructions in reverse order.
Andrew Acton
Membro desde: 03/19/18
469 Reputação
Autoria de 2 guias
Equipe
Baylor, Team S5-G2, Williams Spring 2018 Membro de Baylor, Team S5-G2, Williams Spring 2018
BU-WILLIAMS-S18S5G2
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 600
