Ir para o conteúdo principal
Asus Chromebook Flip C100P Motherboard Replacement
O que você precisa
  1. Asus Chromebook Flip C100P Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the five screws from beneath the rubber feet using a Phillips #0 screwdriver.
    • The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the nine bottom cover screws using a T5 screwdriver. Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them.
    • Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them
  4. Asus Chromebook Flip C100P Motherboard Replacement: passo 4, imagem 1 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 4, imagem 2 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 4, imagem 3 %32
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require extra power. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Motherboard Replacement: passo 5, imagem 1 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 5, imagem 2 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 5, imagem 3 %32
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Motherboard Replacement: passo 6, imagem 1 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 6, imagem 2 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Disconnect the DC jack cable and the battery cable from the motherboard using tweezers, the pointed end of a plastic spudger, or by simply pulling the cables apart from the motherboard with your fingers.
  7. Asus Chromebook Flip C100P Motherboard Replacement: passo 7, imagem 1 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 7, imagem 2 %32
    • Disconnect the LCD cable from the motherboard using the pointed end of a plastic spudger.
  8. Asus Chromebook Flip C100P Motherboard Replacement: passo 8, imagem 1 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 8, imagem 2 %32
    • Disconnect the motherboard to powerboard cable from the motherboard using the pointed end of a plastic spudger.
  9. Asus Chromebook Flip C100P Motherboard Replacement: passo 9, imagem 1 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 9, imagem 2 %32
    • Disconnect the digitizer board cable from the motherboard using the pointed end of a plastic spudger.
  10. Asus Chromebook Flip C100P Motherboard Replacement: passo 10, imagem 1 %32
    • Disconnect the two WiFi antenna cables from the motherboard using the pointed end of a plastic spudger or simply by pulling the cables apart from the motherboard with your fingers.
  11. Asus Chromebook Flip C100P Motherboard Replacement: passo 11, imagem 1 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 11, imagem 2 %32
    • Disconnect the speaker cable from the motherboard using the pointed end of a plastic spudger.
  12. Asus Chromebook Flip C100P Motherboard Replacement: passo 12, imagem 1 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 12, imagem 2 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 12, imagem 3 %32
    • Remove the four 4.2mm speaker screws, then remove the two speakers using a philips head screwdriver.
  13. Asus Chromebook Flip C100P Motherboard Replacement: passo 13, imagem 1 %32 Asus Chromebook Flip C100P Motherboard Replacement: passo 13, imagem 2 %32
    • Remove the five 2.7mm motherboard screws with a T5 screwdriver.
  14. Asus Chromebook Flip C100P Motherboard Replacement: passo 14, imagem 1 %32
    • Remove the motherboard.
Conclusão
To reassemble your device, replace the broken or faulty motherboard with a new motherboard and follow these instructions in reverse order.
3 outras pessoas executaram este guia.
Andrew Acton
Membro desde: 03/19/18
469 Reputação
Autoria de 2 guias
Equipe
Baylor, Team S5-G2, Williams Spring 2018 Membro de Baylor, Team S5-G2, Williams Spring 2018
BU-WILLIAMS-S18S5G2
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 24
Ao todo: 2,644
