Introdução
This prerequisite is required in order to replace or fix some components inside the bottom of the computer.
O que você precisa
Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
11 outras pessoas executaram este guia.
Um comentário
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
