Ir para o conteúdo principal
Asus Chromebook C523N Speaker Replacement
O que você precisa
  1. Asus Chromebook C523N Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Asus Chromebook C523N Speaker Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Speaker Replacement: passo 2, imagem 1 %32 Asus Chromebook C523N Speaker Replacement: passo 2, imagem 2 %32
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Speaker Replacement: passo 3, imagem 1 %32 Asus Chromebook C523N Speaker Replacement: passo 3, imagem 2 %32
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Speaker Replacement, Speaker: passo 4, imagem 1 %32 Asus Chromebook C523N Speaker Replacement, Speaker: passo 4, imagem 2 %32 Asus Chromebook C523N Speaker Replacement, Speaker: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
  5. Asus Chromebook C523N Speaker Replacement: passo 5, imagem 1 %32 Asus Chromebook C523N Speaker Replacement: passo 5, imagem 2 %32 Asus Chromebook C523N Speaker Replacement: passo 5, imagem 3 %32
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
  6. Asus Chromebook C523N Speaker Replacement: passo 6, imagem 1 %32 Asus Chromebook C523N Speaker Replacement: passo 6, imagem 2 %32
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
  7. Asus Chromebook C523N Speaker Replacement: passo 7, imagem 1 %32
    • Gently grab both speakers and lift them from the Chromebook to remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 671
