Introdução
This repair guide demonstrates the step by step process of removing the VECO speakers from the laptop. They are located inside the laptop and under the battery which will require the removal of both the keyboard and the battery before gaining access.
O que você precisa
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
Uma outra pessoa concluiu este guia.
