Ir para o conteúdo principal
Asus Chromebook C300SA-DS02 Trackpad Replacement
O que você precisa
  1. Asus Chromebook C300SA-DS02 Trackpad Replacement, Keyboard: passo 1, imagem 1 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement, Keyboard: passo 1, imagem 2 %32
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 2, imagem 1 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 2, imagem 2 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 2, imagem 3 %32
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 3, imagem 1 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 3, imagem 2 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 3, imagem 3 %32
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 4, imagem 1 %32
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 Trackpad Replacement, Trackpad: passo 5, imagem 1 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement, Trackpad: passo 5, imagem 2 %32
    • Flip over the keyboard assembly to reveal the trackpad beneath.
  6. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 6, imagem 1 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 6, imagem 2 %32
    • Peel up the two pieces of foil tape holding down the trackpad.
  7. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 7, imagem 1 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 7, imagem 2 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 7, imagem 3 %32
    • Use a spudger to release the locking bar of the ZIF connector near the center of the trackpad.
    • Slide the cable ribbon from the connector.
  8. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 8, imagem 1 %32
    • Peel back the ribbon cable, which is adhered to the trackpad.
  9. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 9, imagem 1 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 9, imagem 2 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 9, imagem 3 %32
    • Remove the four 2.5mm Phillips #0 screws along the top edge of the trackpad.
  10. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 10, imagem 1 %32 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 10, imagem 2 %32
    • Pry the trackpad from the top edge with a finger or spudger.
    • Lift the trackpad up and away from the keyboard assembly.
Conclusão
Austin Blakely
Membro desde: 03/11/19
19.389 Reputação
Autoria de 53 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 16.573 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 178
