Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
Open the laptop.
Using an iFixit opening tool, pry along the edges of the keyboard.
Lift the keyboard and slide it gently towards you.
Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
Remove the six 5.6mm Phillips #0 screws around the battery.
Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
Unplug the black and white cable from the motherboard.
Peel back the tape covering the plug.
Slide the cable towards the screen and out of the input.
Unscrew the 6 screws (5 millimeter) on the top right and left.
Gently lift the screen up and away from the laptop.
Pry off the face panel on the screen using the blue prying tool.
Remove the four 2mm Phillips #0 screws from the four corners of the screen.
Gently lift screen
Peel back the adhesive covering the cable.
Remove the cable to free the screen.
Uma outra pessoa concluiu este guia.
Um comentário
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
