Introdução
This guide will walk you through the step by step process of removing the display assembly from the laptop. To replace just the LED screen component within rather than the entire assembly, refer to Asus Chromebook C300SA-DS02 Screen Replacement.
O que você precisa
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
Quase terminado!
Conclusão
