Ir para o conteúdo principal
Asus Chromebook C300MA-EDU Keyboard Replacement
O que você precisa
  1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Keyboard Replacement: passo 2, imagem 1 %32 Asus Chromebook C300MA-EDU Keyboard Replacement: passo 2, imagem 2 %32
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Keyboard Replacement: passo 3, imagem 1 %32 Asus Chromebook C300MA-EDU Keyboard Replacement: passo 3, imagem 2 %32 Asus Chromebook C300MA-EDU Keyboard Replacement: passo 3, imagem 3 %32
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
Conclusão
Christopher Hart
Membro desde: 09/28/17
501 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G3, Nance Fall 2017 Membro de USF Tampa, Team S2-G3, Nance Fall 2017
USFT-NANCE-F17S2G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 692
