Ir para o conteúdo principal
Asus Chromebook C300MA-EDU Battery Replacement
O que você precisa
  1. Asus Chromebook C300MA-EDU Battery Replacement, Keyboard: passo 1, imagem 1 %32 Asus Chromebook C300MA-EDU Battery Replacement, Keyboard: passo 1, imagem 2 %32
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Battery Replacement: passo 2, imagem 1 %32 Asus Chromebook C300MA-EDU Battery Replacement: passo 2, imagem 2 %32
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Battery Replacement: passo 3, imagem 1 %32 Asus Chromebook C300MA-EDU Battery Replacement: passo 3, imagem 2 %32 Asus Chromebook C300MA-EDU Battery Replacement: passo 3, imagem 3 %32
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
  4. Asus Chromebook C300MA-EDU Battery Replacement, Battery: passo 4, imagem 1 %32 Asus Chromebook C300MA-EDU Battery Replacement, Battery: passo 4, imagem 2 %32 Asus Chromebook C300MA-EDU Battery Replacement, Battery: passo 4, imagem 3 %32
    • Once the keyboard is removed, the battery is located on the bottom portion of the shell.
    • The battery is held in with six 6.5mm screws on opposing sides.
  5. Asus Chromebook C300MA-EDU Battery Replacement: passo 5, imagem 1 %32 Asus Chromebook C300MA-EDU Battery Replacement: passo 5, imagem 2 %32
    • The battery is now held in with a tabbed connection to the CPU on the left side of the board. On the tabbed connection, there is a silver plate.
    • Gently push on the silver plate towards the screen until the plastic connection is free.
    • The tabbed connection should now slide out backwards.
  6. Asus Chromebook C300MA-EDU Battery Replacement: passo 6, imagem 1 %32 Asus Chromebook C300MA-EDU Battery Replacement: passo 6, imagem 2 %32
    • At this point, using the plastic removal tool, lift the battery out of the shell.
Conclusão
Christopher Hart
Membro desde: 09/28/17
501 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G3, Nance Fall 2017 Membro de USF Tampa, Team S2-G3, Nance Fall 2017
USFT-NANCE-F17S2G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 361
