Ir para o conteúdo principal
Asus Chromebook C300MA-DH02 Keyboard Panel Replacement
O que você precisa
  1. Asus Chromebook C300MA-DH02 Keyboard Panel Replacement, Keyboard Panel: passo 1, imagem 1 %32 Asus Chromebook C300MA-DH02 Keyboard Panel Replacement, Keyboard Panel: passo 1, imagem 2 %32 Asus Chromebook C300MA-DH02 Keyboard Panel Replacement, Keyboard Panel: passo 1, imagem 3 %32
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Keyboard Panel Replacement: passo 2, imagem 1 %32
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Keyboard Panel Replacement: passo 3, imagem 1 %32 Asus Chromebook C300MA-DH02 Keyboard Panel Replacement: passo 3, imagem 2 %32
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
Conclusão
Juan Pericas
Membro desde: 10/02/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S6-G4, Remmell Fall 2017 Membro de USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 164
