Ir para o conteúdo principal
Asus Chromebook C300MA-DH02 Display Replacement
O que você precisa
  1. Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: passo 1, imagem 1 %32 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: passo 1, imagem 2 %32 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: passo 1, imagem 3 %32
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Display Replacement: passo 2, imagem 1 %32
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Display Replacement: passo 3, imagem 1 %32 Asus Chromebook C300MA-DH02 Display Replacement: passo 3, imagem 2 %32
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Display Replacement, Display: passo 4, imagem 1 %32 Asus Chromebook C300MA-DH02 Display Replacement, Display: passo 4, imagem 2 %32
    • Remove the hinge protector by using the plastic opening tool to gently lift it up. It should come up easily.
  5. Asus Chromebook C300MA-DH02 Display Replacement: passo 5, imagem 1 %32 Asus Chromebook C300MA-DH02 Display Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, separate the display cover bracket from the back of the display. Start from the top.
  6. Asus Chromebook C300MA-DH02 Display Replacement: passo 6, imagem 1 %32 Asus Chromebook C300MA-DH02 Display Replacement: passo 6, imagem 2 %32
    • Remove the (4) four "4mm" screws in each corner that hold the display using the Phillips #000 screwdriver.
  7. Asus Chromebook C300MA-DH02 Display Replacement: passo 7, imagem 1 %32
    • Lower the display to allow access to connector in back.
  8. Asus Chromebook C300MA-DH02 Display Replacement: passo 8, imagem 1 %32 Asus Chromebook C300MA-DH02 Display Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the tape covering the connector with the tweezers.
    • Gently remove the display connector from the motherboard.
Conclusão
Zachary Leonard
Membro desde: 10/02/17
304 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S6-G4, Remmell Fall 2017 Membro de USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 226
