Ir para o conteúdo principal
Asus Chromebook C300MA-DB01 Screen Replacement
O que você precisa
  1. Asus Chromebook C300MA-DB01 Screen Replacement, Screen: passo 1, imagem 1 %32 Asus Chromebook C300MA-DB01 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Use plastic opening tool to remove the frame around the screen. It is recommended to start in the upper corners.
  2. Asus Chromebook C300MA-DB01 Screen Replacement: passo 2, imagem 1 %32 Asus Chromebook C300MA-DB01 Screen Replacement: passo 2, imagem 2 %32
    • Use plastic opening tool to remove plastic hinge casing located between the screen and keyboard.
  3. Asus Chromebook C300MA-DB01 Screen Replacement: passo 3, imagem 1 %32
    • Use 64 bitdriver to remove 4 6.0 mm Phillips screws from screen the screws that need to be removed are located in the corners of the screen.
  4. Asus Chromebook C300MA-DB01 Screen Replacement: passo 4, imagem 1 %32
    • Use plastic prying tool to detach the wire that connects the screen to the lower non-display half of the laptop.
  5. Asus Chromebook C300MA-DB01 Screen Replacement: passo 5, imagem 1 %32
    • Lift and remove screen from the laptop.
Conclusão
wyatt boyatt
Membro desde: 09/25/17
541 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S4-G3, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 9
Duração total: 339
