Introdução
If you are encountering issues with your display this guide can be very useful. The removal of the casing from the screen can be difficult be sure to gently use the opening tool around the whole perimeter and not in one location.
O que você precisa
Use plastic opening tool to remove the frame around the screen. It is recommended to start in the upper corners.
Quase terminado!
Conclusão
