Ir para o conteúdo principal
Asus Chromebook C300MA-DB01 Battery Replacement
O que você precisa
  1. Asus Chromebook C300MA-DB01 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Battery Replacement: passo 2, imagem 1 %32
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Battery Replacement: passo 3, imagem 1 %32
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Battery Replacement: passo 4, imagem 1 %32 Asus Chromebook C300MA-DB01 Battery Replacement: passo 4, imagem 2 %32
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Remove the six 6.0mm Philips screws, using the 64 bit driver from around the battery.
  6. Asus Chromebook C300MA-DB01 Battery Replacement: passo 6, imagem 1 %32
    • Unplug the wire using the plastic opening tool that connects the battery with the board.
  7. Asus Chromebook C300MA-DB01 Battery Replacement: passo 7, imagem 1 %32
    • Lift the battery out of the laptop
Conclusão
Uma outra pessoa concluiu este guia.
wyatt boyatt
Membro desde: 09/25/17
541 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S4-G3, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 20
Duração total: 2,254
