Introdução
This repair guide provides step-by-step instructions for replacing the keyboard of the ASUS Chromebook C300M-BBCLN12 keyboard. The repair may be required if the keyboard is no longer functional.
O que você precisa
Remove the eight 9.0mm PH00 Phillips screws along the perimeter of the bottom housing.
Remove the three 6.0mm PH00 Phillips screws from the center of the bottom housing.
Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
Disconnect the wide black cable from the motherboard by pulling the blue cable tab straight out of the connector.
Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab straight out of the connector.
