Ir para o conteúdo principal
Asus Chromebook C300MA DB01 Screen Replacement
O que você precisa
  1. Asus Chromebook C300MA DB01 Screen Replacement, Screen: passo 1, imagem 1 %32 Asus Chromebook C300MA DB01 Screen Replacement, Screen: passo 1, imagem 2 %32 Asus Chromebook C300MA DB01 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Use a Jimmy to pry off the hinge cover from the screen.
  2. Asus Chromebook C300MA DB01 Screen Replacement: passo 2, imagem 1 %32 Asus Chromebook C300MA DB01 Screen Replacement: passo 2, imagem 2 %32
    • Run the Jimmy along the edges of the screen frame to unsnap it from the connectors.
    • Remove the screen frame manually.
  3. Asus Chromebook C300MA DB01 Screen Replacement: passo 3, imagem 1 %32 Asus Chromebook C300MA DB01 Screen Replacement: passo 3, imagem 2 %32 Asus Chromebook C300MA DB01 Screen Replacement: passo 3, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the four screws on each corner of the screen.
    • Separate the screen from the top of the Chromebook with the Jimmy.
    • Avoid pulling the screen too far from the device as this can disconnect the wire located at the bottom of the screen.
    • Use the Jimmy to lift the latch on the wire jack.
    • Remove the wires and detach the screen from the device manually.
Conclusão
Earl Gill IV
Membro desde: 04/01/19
193 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S10-G10, Wilson Spring 2019 Membro de IUPUI, Team S10-G10, Wilson Spring 2019
IUPUI-WILSON-S19S10G10
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 127
