Ir para o conteúdo principal
Asus Chromebook C300MA DB01 Battery Replacement
O que você precisa
  1. Asus Chromebook C300MA DB01 Battery Replacement, Removing the Back Cover: passo 1, imagem 1 %32
    • Remove the eight 9.0 mm Phillips screws along the perimeter of the case.
    • Remove the three 6.0 mm Phillips screws from the center of the case.
  2. Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: passo 2, imagem 1 %32 Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: passo 2, imagem 2 %32
    • Slide the Jimmy in between the keyboard and underside of the laptop to remove the keyboard.
    • Leave the keyboard face down on the screen.
    • Do not pull the keyboard away from the laptop. The keyboard will still be attached with wires.
  3. Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: passo 3, imagem 1 %32 Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: passo 3, imagem 2 %32
    • Use a nylon spudger to lift the latch on each wire jack and detach the keyboard wires.
    • After the tabs have been lifted, the wire can be gently pulled out by hand.
    • Set the keyboard aside.
  4. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: passo 4, imagem 1 %32 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: passo 4, imagem 2 %32 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: passo 4, imagem 3 %32
    • Remove the six 6.0mm Phillips screws on the battery.
    • Remove the wire jack from the battery. Use a nylon spudger to lift the latch.
    • Remove the battery from the device.
Conclusão
Earl Gill IV
Membro desde: 04/01/19
193 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S10-G10, Wilson Spring 2019 Membro de IUPUI, Team S10-G10, Wilson Spring 2019
IUPUI-WILSON-S19S10G10
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 195
