Ir para o conteúdo principal
Asus Chromebook C300M USB Port Replacement
O que você precisa
  1. Asus Chromebook C300M USB Port Replacement, USB Port: passo 1, imagem 1 %32 Asus Chromebook C300M USB Port Replacement, USB Port: passo 1, imagem 2 %32
    • Flip the chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M USB Port Replacement: passo 2, imagem 1 %32
    • Separate the plastic case from the keyboard at the seam using a plastic opening tool.
  3. Asus Chromebook C300M USB Port Replacement: passo 3, imagem 1 %32 Asus Chromebook C300M USB Port Replacement: passo 3, imagem 2 %32
    • Fully separate the plastic case from the keyboard by lifting it upward.
  4. Asus Chromebook C300M USB Port Replacement: passo 4, imagem 1 %32 Asus Chromebook C300M USB Port Replacement: passo 4, imagem 2 %32
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
  5. Asus Chromebook C300M USB Port Replacement: passo 5, imagem 1 %32 Asus Chromebook C300M USB Port Replacement: passo 5, imagem 2 %32
    • Disconnect the USB port in the top right corner from the motherboard.
    • Unplug the the wide ribbon cable using spudger.
  6. Asus Chromebook C300M USB Port Replacement: passo 6, imagem 1 %32 Asus Chromebook C300M USB Port Replacement: passo 6, imagem 2 %32
    • Remove the single 3mm screw on the left and bottom side of the USB Port using the Phillips #1 screwdriver.
    • Remove the three 5mm screws on the upper part of the USB port with the same screwdriver.
    • Lift the edge of the white casing. Remove the USB Port by pulling it toward the bottom of the laptop.
Conclusão
Rachel Cadle
Membro desde: 04/02/19
259 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G2, Harley Spring 2019 Membro de IUPUI, Team S3-G2, Harley Spring 2019
IUPUI-HARLEY-S19S3G2
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 763
